btboone
I tried to do a polyester pen with two different colored resins in an interlocking pattern. I wasn't thrilled with the results. I had tried the same technique on the Puzzle pen I had done and never got the resin to cure. That was done in wintertime, so I wondered if the temperature had a lot to do with that. I tried it again and got the resin to cure, but it still didn't fill the alternate areas like I would like. I had to laser the pattern pretty deep in order to fill above it, and the heat distorted the cut line slightly. I think that the residue left over from lasering must play a part in the resin not curing right in the dividing point.
I am still toying with the idea of doing it in two colored woods, but the laser beam gets wider as the wood gets thicker. I would need to compensate for the beam width and match the draft angles to make that work. I think I would also lose a lot of detail that way. Another thing to try is simply engraving a shallow distance and coloring the lasered stock in a contrasting color. The detail is much crisper that way. The top of the pen will have rotating dice to complete the theme.
