btw, heard an interesting tidbit the other day explaining the little loose ball inside them.
On the cartridges, it's obviously there to plug up the hole until you punch it onto the nipple, but I never understood it's purpose on the converters.
It was said the little ball rolling around helps to break up the surface tension of the ink on the sidewalls and top of the converter, thus making it easier for the ink to flow from end to end and not getting stuck up on the top end.
Makes some sense, but if that's the case, why aren't they in any of the higher end/higher priced ones, even from the big boys??
