Fountain Pen Kit Less than 1/2" Diameter
mbroberg
Columbus, OH
Does anyone know of a fountain pen kit that has a finished diameter of less than 1/2"? I thought the Stretch might, but that measures 33/64 tapered down to 31/64". I (meaning my customer) would like it less than 1/2" the entire length of the pen. Any suggestions?
ed4copies
Local Chapter Manager
Racine, WI, USA.
Mike,
The thinnest one I know of is the old Presidential or Executive (same diameter tubes--10mm I believe). It was a straight barrel, end to end. Could be kept right around .5", I would think.
Have hundreds of them in the shop, will send you one--its a rollerball, but we can easily convert, I think. The CSUSA replacement nibs screwed right in, IIRC.
Will check tonight.
After thinking about it a little, it would also be a pretty good closed end pen, so you could cheat a bit, make the hole "stepped" to accommodate just the size of the refill.
corian king
chesapeake va
Hello The smallest I can think of would be the classic fountain pen.I checked a couple that i have just finished and they are right at 5/8. I don't think I could have gone any smaller.
Good luck!
JIM
BigShed
Adelaide, SA, Australia.
This one
http://www.timberbits.com/cigar-americana-fountain-pen-kits.html
and this one
http://www.timberbits.com/flat-top-americana-fountain-pens.html
David ships to the US and his service is very good.
Here is one of the Cigar Americans, the shorter of the 2
Old Lar
Sturgis, SD
I have a customer that likes smaller fp's also. I use the roundtop from Ernie at Beartooth or the Traditional. Both are just at 1/2 inch.
