Flush Finish With Nib and Center Ring
Allsmiles
Gurnee, IL
Hi, I am just starting out and have only made a few pens. I am having a problem with the final fit and finish.
After I have turned the blank flush to the bushing, I am applying a CA finish. I don't think I am applying to much CA based on all the videos I have watched. Usually 5 coats of medium CA
Once assembled, the polished pen blank is no longer flush with the nib or center ring. There is a slight lip.
Do I need to be sanding slightly past the bushing to achieve a final flush finish?
renowb
I ususally bring my sandpaper past the blank and onto the bushing, just to get a good sanding to the end. I'm sure more people will chime in with their processes.
hunter-27
Passed Away Aug 14, 2013
Chadron, Ne, USA.
short answer--yes
longer answer-- the finish you are putting on to protect the wood is a build up of layers of CA(essentailly a coat of plastic) those layers, while thin, will increase the diameter of your barrel slightly and that is most likely what you are feeling. Best option is to use a set of calipers to match the finished barrel to the hardware being used.
Brooks803
Aiken, South Carolina
Yes. You want to start with the blank a hair under the bushing and then build up to size with ca. Also get yourself a caliper and check your blanks final diameter to the actual part. Don't rely on bushings bc they wont always match the kit parts perfectly.
Rangertrek
Bossier City, Louisiana, USA
You can also use a set of drafting needle dividers to do a spot check on the parts, bushings, and your blank. Then verify with the calipers. I have found I can get very good results with just the dividers.
