Dan_F
Is there a way to repair small chips at the ends of barrels? These occured as I was using the pen mill to true up the ends, the mill chattered, even though it just came back from being sharpened. It left the ends of the blank and even the brass tubes kind of ugly. The chips are actually quite small, and wouldn't be noticed by the casual observer, but then who wants those? If I waxed my bushings, could I apply some thick CA mixed with sawdust between the blank and bushing to fill in the chips without the CA sticking to the bushings and causing ever more problems? ?
This brings up another question, which is, can a 3/4" mill be used on blanks larger than the mill? Not sure if this was the source of the chatter, seems the first few pens I did were free of this problem, but they were harder wood, whereas the pen in question here is buckeye burl, kind of soft but not quite punky.
Well, on further investigation it seems that I used the wrong diameter pilot for the mill (one size smaller than the largest in the WC kit), so that might have been part of the problem (he admitted sheepishly).
Dan
Dan
