I see part of the problem. You should try turning in a horizontal position. I find it better for stuffing sawdust back into those holes.
Try engraving Ostrich egg some time did this at home had to take the laser outside and hook up the exhaust as is smelt so bad. We do not do eggs any more:biggrin:Just wait once you get good at making wood round you will want to move on to more exotic materials..........Bone not only explodes it stinks! Strongly enough to end a happy marriage! And musk ox horn! Just dont if you have any respect for your neighbors, when it comes to Musk ox horn!
Yeah, you are definitely an amateur. Just look at that little hole. Those of us that have been doing this for a while can make the whole blank explode and disappear into dust and shrapnel so the only thing left is a battered brass tube. :biggrin:
how do you get this luck! I explode only one side and i have to turn off the other side..[/quote]
Turn more, lots more!:wink::biggrin:
Charles
I've heard of folks making pens on a drill press. Is that what you're doing? (I've got a lot room to talk as I'm probably newer than you are.) Big learning curve ain't it?
Joe
