finishing dymondwood
johnkepka
St. Louis, mo, USA.
I am new to using dymondwood. I would appreciate some finishing tips or suggestions. I did sand to 1500 and tried the novus 1 and 2 but found it low gloss and generally unsatisfactory. It seems results were 1200 then eee shine and PPP.
I am told it can be wet sanded to a finish but this did not seem to be that good.
Part of the problem could be that it is the red white and blue "olymmpic " pattern.
thanks
john kepka
Rudy Vey
South Plainfield, NJ, USA.
Sand with MM through all grits, then polish with an automotive polishing coumpound or Novus polish and finish with a couple of coats of TSW. There is no need for an additional finish, this is resin containing stuff and needs, in my opinion, nothing on top of it.
wayneis
Okemos, Michigan, USA.
I make quite a few dymondwood pens and when finished they look like I did a Enduro or CA finish on them. I sand with MM to 12,000 then buff with white dymond, that makes them shine like crazy.
Wayne
TomServo
Grand Forks, ND, USA.
I turned one real quick just now - check it out
sanded 150,220, green, red, gray scotch brite then wet sanded with BLO from 1000, 1500, and 2400MM-12000MM i wiped off the excess BLO and used both sticks of PPP (it's what i got)
