Finishing Acrylics Complex Shapes - Page 3 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 12-09-2016, 01:11 PM   #21 (permalink)
TonyL's Avatar
Photos: 6
Default
Michael send me your address and I will send you some Dr. Kirk's. I have not not been able to achieve the advertised results with it.
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Old 12-09-2016, 02:19 PM   #22 (permalink)
New Member Advocate
Edgar's Avatar
Photos: 23
Default
Rather than the square MM pads, you might try MM sheets like these:
https://www.amazon.com/SANDING-SHEET...A2NWLOWWF5G7JX
They are more flexible than the pads and should work better on complex curves. I cut them into 1" x 3" strips and they last a long time. After going through one set of the square pads, I tried the sheets and have never looked back. You can also get them in larger-sized sheets.
__________________
Eat pecans - 10,000,000 squirrels can't be wrong.
Edgar is offline   Reply With Quote Top
Old 12-09-2016, 03:57 PM   #23 (permalink)
Mike@CSUSA's Avatar
Photos: 0
Default
Quote:
Hey Tony,
How are you applying it? And what results are you getting?
My polish method goes like this. 320 grit, 400 grit, 600 grit, with lateral sanding between each grit, then Scratch free polish at 3000 rpm, then Micro magic 1, 2, 3, at 3k rpm with lateral sanding between each polish. Then lastly, I'll use a plastic polish. It cuts down a huge amount of time for me polishing acrylics as opposed to wet sanding with Micro Mesh.
I like to use small flannel squares to apply the polish because most pape r towels are too rough.
This watch pen I did using that method.
Mike@CSUSA is offline   Reply With Quote Top
Advertisement
Old 12-09-2016, 04:46 PM   #24 (permalink)
mecompco's Avatar
Photos: 10
Default
Tony, thank you very much for the offer. I've already ordered a set from CSUSA. Perhaps someone else would like to take you up on your generous offer.
Regards,
Michael
mecompco is offline   Reply With Quote Top
Old 12-09-2016, 04:53 PM   #25 (permalink)
liljohn1368's Avatar
Photos: 62
Default
I will buy it from you, Tony. If you still have it...
liljohn1368 is offline   Reply With Quote Top
Old 12-09-2016, 08:40 PM   #26 (permalink)
TonyL's Avatar
Photos: 6
Default
Quote:
Hey Tony,
Hi Mike.
Thanks for the advice. You and I spoke over a year ago about it when I called CSUSA. I was using it just as you advised me. Didn't you say you were part of the test group?
Anyway, it does reduce the size of scratches, just not as much as I would like it to - I am not blaming the product... I am sure it is me and the magnification under which I inspect my work.
Best to you and thanks again.
__________________
Peace,
Tony
Old 12-09-2016, 08:41 PM   #27 (permalink)
TonyL's Avatar
Photos: 6
Default
Quote:
PM sent. I am giving some away. I promised some to others too.
__________________
Peace,
Tony
Old 12-13-2016, 07:23 AM   #28 (permalink)
Quality Pen's Avatar
Photos: 4
Default
Quote:
Originally Posted by gwlundgren View Post
I'm relatively new to turning acrylics/plastics.
I've kept my acrylics shapes fairly simple due to the difficulty of getting them smooth and shiny.
Working with the little square wet sanding pads can leave grooves, lines, and ruts in the shapes.
Is there a way to get these smoother?
Thanks! Gary
When I started I did all the wet sanding jazz, but once you start getting good at buffing that's where the magic really happens ;)
There's a great thread here called kicked up a notch that helped steer many users here.
__________________
"And finally, it CAN BE DONE. It HAS been done by more than one member here." -PenMan1
Quality Pen is offline   Reply With Quote Top
Old 12-22-2016, 02:29 AM   #29 (permalink)
Photos: 0
Default
Look into flame polishing. More than a few of the duck call guys are doing it, and flame polishing has a long history of use in the wider world of plastics fabrication. It does, btw, need to be flame. A heat gun doesn't put out enough concentrated heat.
Bikerdad is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Tags
acrylic , pen
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
