Filling blank voids
Woodlvr
Midvale, Ut,
Would there be any reason why antler dust could not be used to fill voids in a wood blank? I have not attempted this before and was not sure if it would bond and lood good. TIA for your help.
workinforwood
Eaton Rapids, Michigan, USA.
I see no reason why it won't work. I wouldn't personally bother because the antler dust is not exactly safe to be around, so I would not be collecting and storing it. I would choose something else, like grinding dust of some corian. You still need a mask of course, but there won't be any bacteria in the corian.
Woodlvr
Midvale, Ut,
Thanks all for the input. Jeff I think that I will try to grind some white corian, I had not thought of it. I had some small plastic case with shavings and the only white that I had was antler. Thanks again.
