robutacion
Hi everyone,
Everyone knows that I like to play with wood and PR, some products I put for sale here and on my eBay store, others I use myself but of all batches or new woods I come up with, a sample is cut, turned and finished with CA, no different as if it was in the barrel(s) of the best pen kit available.
I take some pics of each face of the blank/sample and put it a side in my collection box, which is growing to a large size, indeed...!
The idea was always make a display of these samples, in a rack where I could hang these samples side by side in a line or cable from wall to wall, sort of thing.
The original idea was to make this suspension rack in my computer room, where I could admire these samples, every time I want, instead of spend a lot of time, "shoveling" in the big box to find what I want...!
A few years ago, this was quite manageable but now, no way Jose...! I keep making too many of these.
To me, is like making a pen from these blanks, really. The excitement to rip a log into a pen blank size, turn it and finish it so see how it comes up, is great stuff. No different or in fact worse when it come to the Resifills, as I never do the same thing twice, even if I try which is a pain sometimes when I make an exceptional mix, so in general, good or not so good, it happen in lots of 18 blanks ( 3 molds of 6 blanks each)...!:biggrin:
I made it a rule to only make the Resifills only in late afternoon, the last thing for the day, sort of thing. Many times I'm pouring resin late at night if earlier on wasn't possible, the reason to this is that I like the "feeling" of having something to look forwards in the morning/next day, there is, see what I've done...!
The first step is to get the molds off the pressure pot and put them in the sun to dry, then in the afternoon the serious work commences, the molds are dismantled, the blocks are sliced into pen blanks, and before the day is over, I have to have one of those blanks (totally random, as most times you can't see what is inside until it is polished and coated with some sort of liquid), turned and CA finished...!:wink::biggrin:
The pics are normally taken the next day or even immediately after the sample has been finished as, some of these samples are far from dry/set, they are still soft, some still bleeding, etc., etc. so, I know that the next day will be too late to take the pics as the finish will be spoiled, the one way or the other. I don't mind to re-do them later, as they will be hanging in the shed ceiling for a few weeks to cure properly before they go in the box.
Is that excitement to finish a sample to be able to see properly what I've done, what I like the most about making Resifills, the steps, process and poisoning fumes, not counting the horrendous smell of working with PR, are certainly not something that I enjoy that much...!
In between the negatives and positives of making Resifills, I do enjoy very much the excitement/expectation they give me...!:biggrin:
Turning and finishing samples from solid wood, is in no way less exciting, particularly woods that I never seen or worked with before. With wood, the samples take a few different shapes/cuts styles as wood will provide a totally different look, depending of how it is cut from the log and then the board...!
So, is not rare, in fact almost a requirement that the same wood is cut into 3 common cutting types, straight cut, diagonal and cross, therefore resulting in the making of 3 samples from the same wood.
Isn't difficult to understand why the samples box size at the moment is a very large one and why I'm getting concern about the weight and number of these samples require to be hang in that display I mention above. In fact, I look everyday to the only wall where this display can be built and I'm starting to wonder, if I have enough wall for what I have at the moment, already...!
I need to get them out of the box, that is no doubt, I may need to re-design my original drawings for this line/cable suspension samples display, the strength and support areas are now crucial, there are a "few" hundred" to hang...!:wink::biggrin:
Well, the purpose of this tread is to share with you all, just some of the recent samples I've made, between solid/full wood, Resifills and some full PR resin. Lets say that they are what I've done in the last 3 months, that will be enough for now. Some of samples made prior to this lot has been displayed here, some on my classified adds.
Enjoy the ride...!:wink:
PS: The day that I get these samples display done, you will be the first ones to know/see it...!:wink::biggrin:
NOTE: In the beginning of this thread I didn't know how many pics I would end-up with, I have it reduced to 39 at about 3.2MB total size. It may take a little longer to download to those with very slow internet speeds, and I do not think that dividing the number of pics in various posts will make any difference, nevertheless, I apologize for that and if the Mods think that is a better way to do this, please let me know...!
Cheers
George
Cheers
George
