I have a theory about what happened, but I'd rather hear from someone else first.
I was drilling Corean, two half inch pieces glued together with CA.
I was drilling 7mm holes with a COLT brad point bit.
It was the eleventh half blank I was drilling, all of them either Corian or acrylic.
For every blank I was drilling about 1/4 inch then stopping and dipping the blank in a bucket of water. I also dipped the bit into a cup of water every time I stopped.
About 1 1/2 inches into this blank I heard a pfffft sound. I stopped, dipped the bit and blank and started up again.
When I started drilling again I felt a pressure preventing the bit from going down, so I pushed a little harder. Again I heard the pffft sound and this time there was a pop and warm, wet, gritty slurry splashed into my face.
I dipped and cooled bit and blank again and tried again, this time when I put more pressure on the drill press it popped again and the blank split in half on the glue line.
With the blank split in half I could see that there was a gummy build-up of slurry on the inside of the tube.
Why did this happen?
Gerry
Gerry
