mecompco
Anyone have suggestions on how to disassemble an Executive? Have not been able to make the normal punch solution won't work as the hole left after the tip punches out (leaving the pressed-in part) is the same diameter as the hole in the top after the transmission is removed. One can sort of tap at an angle to just barely catch the part with the punch, but not enough to move it.
Thanks for any ideas!
Regards,
Michael
Regards,
Michael
