Executive Clicker vs Artisan Clicker
southernclay
Dawsonville, GA
Is the Artisan (Long) Clicker from CSUSA the same as the Timberbits Executive Clicker as far as bushings?
CSUSA is 3/8" drill bit and Timberbits is 9.5 mm only .010" difference there, look similar.
Just wondering about bushings and quality comparison, I like the CSUSA version just cutious as to the comparison.
Thanks!
Bean_Counter
Lubbock, TX
Warren, I just received 2 long clickers from Timberbits (wanted to test drive them first). I'd say the quality is the same. I used a 3/8 bit on mine (same as CSUSA) and had no problems there. The one thing that was different was the clip. The top of the clip on the Timberbits one stuck past where the clip is inserted into the barrel so using the extra piece they send you to press in the clip/button is a must. If that doesnt make sense let me know and I will post a pic for ya.
As far as bushings I couldnt answer that as I TBC, but my TBC bushings worked just fine for me (I mic the blank down and build back with CA)
