euro pencil conversion?
byounghusband
Celina, Texas, USA.
I once did a modified Slimline pencil with a Corian centerband in it. I drilled the center of the CB deep enough to hide the center part of the pencil mechanism in it. It was a long time ago and it took a couple tries to get it to work.
I would have to try to refigure what I did to explain it better. Hopefully, someone else has a better idea.....
Randy_
Dallas suburb, Texas, USA.
Just a guess; but you may be able to do the same conversion that Scott wrote about for the Sierra and works for the cigar as well. Buy a Schmidt DSM 2006 pencil cartridge from Arizona Silhouette and have at it!!
gerryr
Billings, MT, USA.
Originally posted by Randy_
<br />Just a guess; but you may be able to do the same conversion that Scott wrote about for the Sierra and works for the cigar as well. Buy a Schmidt DSM 2006 pencil cartridge from Arizona Silhouette and have at it!!
Not if it's a 7mm euro. That conversion would work for an 8mm, but not for a 7mm. Even though it would work, just getting the pencil kit will result in a better made pencil, with an eraser too.
Firefyter-emt
Putnam, Connecticut, USA.
Make the cap a with 2 tubes like the El-Grande Streamline 8mm tube and a small section of 7mm in the very end to install the final. It would take a bit of work, but not too hard to do.
