Hi,
When I first started I used to use either medium or thick CA and accelerator - mainly because I always seemed to be in a rush to get a pen started and completed.
I have now decided that patience is key and have started using Stick Fast 5 min epoxy. I use Play-Doh to plug the tubes when I glue, but still get a little epoxy on the inside edge sometimes - which I remove.
I have seen in some posts that advise that all epoxy should be removed completed from the tube to avoid pen failure.
I am just curious about what type of pen failure occurs if any epoxy is left. Does it come off over time and affect the mechanism?
Steve
Steve
