Stephen
Is it possible to engrave names on pen clips that are TN Gold or Rhodium? If OK. which is the best method? Thanks .
Stephen
Stephen
It CAN be done with a laser but not as actual engraving. There is a material that they can apply as a base and then laser. The laser burns the base material onto the metal and then they clean off the un-burned base. It looks good but I only had it done on the back of a Sierra top. Hitting the clip right on would be tricky I would guess but could be done. The one I had done still looks great after many months of use.
