Bozz
I recently purchased a couple of El Grande Pens from Woodcraft in Sacramento, CA.; two of each, the rollerball & fountain pen. I failed to turn a clean, straight body - had a tear out. The 'skin' of the wood over the brass tubes was very thin, < 1/16th inch.
The mandrel, pen kit and bushings all came from Woodcraft.
The second attempt is better [the one on the right]. However, the wood is so thin you could -almost- floss your teeth with it. How well will this hold up? It seems too thin to last! If I make the body thicker, the parts will not fit. Is this typical of this style of kit? What am I doing wrong? Thank you all for your comments and to let you know, I am a new pen turner.
Thanks,
Bozz
Thanks,
Bozz
