| Penturning General penturning discussions not specifically addressed in one of the specialty forums. |
LinkBack | Thread Tools | Display Modes |
#22 (permalink) | |
Quote:
Dennis; I have made material prone to cracking in the past. I used a transfer punch to "expand" the brass tube slightly at the ends so the fitting is a slip fit, then put a drop of thick CA on the inside of the tube, and insert the fitting with a twisting motion. Use a punch just smaller than the tube. Insert the punch about 1/4" into the bare brass tube and twist it sideways until the fitting just slips into the brass.
__________________
Randy S.
I have a written set of life rules: 6. A person (politician) who speaks of sacrifice at length is talking about someone else, not themselves. |
#23 (permalink) |
Lee, one thing I discovered with this kit (and don't really have a solution for it) was when using a polyresin blank the larger tube shows thru differently then the lower tube does on the cap blank. I reverse painted the blank and the tube, but it created a visible shading difference at the transition. Not sure if that description makes sense ... I couldn't find pics (probably because I didn't want it seen...
| Bookmarks |
| Tags |
| el grande , instructions , tube gluing help , tubes |
| Thread Tools | |
| Display Modes | |
