Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Reply
Old 03-21-2011, 01:27 PM   #1 (permalink)
Lenny's Avatar
Photos: 47
Default El Grande questions?
I just picked up a few of the Berea El Grande kits and find the instructions and methods used much different from any other pen I have done to date.
The cap end has two tubes a smaller one that fits in the 11mm hole and a large (short) one that fits in the top end.
On the upper cap blank you are required to cut the blank to 1 7/8" and then drill a 11mm through hole. . I have drilled the hole and THEN cut the blank back to 1 7/8" ... now for the odd part .... you are then supposed to drill the cap end of this blank to a depth of 3/4 " using a 33/64" bit. Ok, I have done that too! .... BUT now, according to the instructions, you insert the tubes with NO glue and place them on the mandrel and using the bushings, turn to size!
Now it seems to me that any blank once the holes are drilled, is a little sloppy.... of course it doesn't matter once the tube gets glued in you can use your barrel trimmer or disc sander setup to "true" the ends.
How in heck do you expect to get good results with this method?
Am I missing something? Should I just keep going and expect everything to work out? Should I attempt to use a barrel trimmer even though the tubes are loose?
I can't say this set of components will become one of my favorites!
Thoughts and opinions welcome.
Lenny is offline   Reply With Quote Top
Old 03-21-2011, 02:14 PM   #2 (permalink)
Photos: 8
Default
what instructions are you looking at Lenny?
http://www.beartoothwoods.com/faq/ElGrandeRBF.pdf
George Watkins is offline   Reply With Quote Top
Old 03-21-2011, 02:24 PM   #3 (permalink)
PennedDown's Avatar
Photos: 7
Default
Lenny,
I'm wondering the same thing. I've made a lot of El Grande's.
A 31/64" bit for the lower barrel and a 33/64 for the upper barrel (I use a 13.3 mm for the upper)
__________________
Dale
What you leave behind is not what is engraved in stone monuments, but what is woven into the lives of others.."
PennedDown is offline   Reply With Quote Top
Old 03-21-2011, 02:30 PM   #4 (permalink)
broitblat's Avatar
Photos: 379
Default
The kits that requires two tubes in the top are different than the normal "El Grande". The "El Grande Streamline" uses two tube sizes for a more dramatic taper in the cap. I made a few of these a while back, and it's not as difficult as it sounds (I'm not sure I actually followed the directions, though). Berea also has the "El Grande Elite" on special which uses the more "normal" techniques you're probably used to.
-Barry
__________________
Nice play! (well, it's not exactly work, is it?)
Barry Roitblat
Bellevue, WA
broitblat is offline   Reply With Quote Top
Old 03-21-2011, 02:58 PM   #5 (permalink)
Lenny's Avatar
Photos: 47
Default
These ....
http://www.bereahardwoods.com/price/...l_fountain.pdf
Old 03-21-2011, 03:03 PM   #6 (permalink)
Lenny's Avatar
Photos: 47
Default
Quote:
-Barry
Yes, Barry ... you are right, it is the Streamline. So did you use a barrel trimmer or some other method to true up the ends of the blank before turning? Maybe I'm making too big a deal of it but I just see lots of room for error here and resulting gaps between material and components.
Perhaps I should just continue and worry about fine tuning the ends later with a sanding mill.
Old 03-21-2011, 03:09 PM   #7 (permalink)
Photos: 0
Default Streamline Instructions
Lenny, if you bought the same kits I bought, the cap instructions on the back of the page gives the reason not to glue in the tubes yet.
__________________
Barry L Elder
nativewooder is offline   Reply With Quote Top
Old 03-21-2011, 03:17 PM   #8 (permalink)
Lenny's Avatar
Photos: 47
Default
Quote:
Yes, I understand the reason ... it's the process that I worry about.
Old 03-21-2011, 06:13 PM   #9 (permalink)
JMT
JMT's Avatar
Photos: 0
Default
Yeah....I agree...pretty strange. I'd have to actually make one to see how well that system works out. Looks like a good opportunity for the step-tubes. (Which means you have to then go buy a step bit for the step tube.....grrrr...)
Anyway....good luck.
JMT is offline   Reply With Quote Top
Old 03-21-2011, 06:16 PM   #10 (permalink)
Lenny's Avatar
Photos: 47
Default
Well, I went ahead and attempted to turn the cap they way they describe in the instructions by fitting the two different sized tubes in the blank loose with no glue and mounting them with the bushings for turning. The result, as I suspected, is an out of round turning!
Reply
Bookmarks
Tags
el grande , instructions , tube gluing help , tubes
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Copyright © 2003-2012 by Penturners.org, LLC; All Rights Reserved
