KenV
Watched the Ed Brown video series again. It is worth doing again from time to time.
This time I was paying attention to the skews Ed was using.
What I saw:
Oval Skew
1 1/8 or so in width
Ground straight across with "drooping corners"
Moderate included angle -- estimated at about a 40 degree setting on my grinder table (I use a RoboRest)
Could not tell if he hones/sharpens the points but Ed does not use the points regularly so probably not.
Drooping corner amount was not consistent in,the videos, but some drop was visible. Perhaps the arc of a 50 cent piece at the most.
So----
I have a 3/4 inch over Sorby skew that was not seeing much use so I put an Ed Brown Grind on it. I tend to use the,point so honed both points along the side of the shank of the tool to get a sharp point.
Works well. This is a speed improved. Less messing with the tool. Left to right and sight to left and never take the tool off the took rest.
Single point cuts easily.
I like it!
Thanks Ed!!!
What I saw:
Oval Skew
So----
I like it!
Thanks Ed!!!
