Im in the process of making my first pen from ebonite. It's black ebonite but all the shavings from it while turning are brown. It also has an unusal smell.
I haven't assembled the pen yet because i have a few questions.
How do you finish it? I did one barrel, final turning with a skew. No scratches. Started sanding with 320 grit (wet sanding all). Sanded lenthwise with the lathe off with 400 wet and then micromeshed and novus polished it. It looks fine. When I step out into the sunlight with it, it appears to have tiny scratches all over it going across barrel and up and down as well. What did I do wrong? Or is that just the way it looks.
Any help would be appreciated.
