Easiest way to disassemble a pen 7&10mm
philb
Midlands, United Kingdom.
Hi,
Just want to disassemble some of my older turned 7mm pens and also some cigars. Want to give them a coat of CA finish as im trying to perfect it, so may aswell use some older rubbished finished pens!
Any ideas that I can use without having to buy one of the dis-assembler tools! lol
madison, wi, USA.
bI use a 1/8" rod purchased at a hobby shop and a 1/4" long bolt.
Hold the pen firmly and tap the nib out with the 1/8" rod through the transmission.
Then use the 1/4" bolt passed up through the pen end to force the transmission out.
You can drill a block longer than the transmission with a hole larger than the transmission and smaller than the pen diameter. A press will then force the transmission out.
Larry
http://webpages.charter.net/lgottlieb2/
Scott
Blackfoot Idaho
As Shannon said above, the transfer punches are the way to go! You can then disassemble most any pen using them. Lots of other uses as well.
Scott.
skiprat
Passed Away Mar 22, 2022
In a Skip in Wales
I just use the back end of drill bits. Biggest size that goes in and smack the sharp end with a plastic mallet. For stubborn fittings I hold the barrel while wearing a garden glove with rubber studs.
thewishman
Reynoldsburg, Ohio, USA.
Wrapping a rubber band around the barrel helps you hold it when disassembling. <s>I</s> (cough cough) I mean my friend has had lots of experience in taking pens apart. The HF transfer punches have paid for themselves many times over.
Chris
