cwasil
I just built several dymondwood pens and had some problems with the prep work. The turning and finishing of these pens was a breeze but the drilling and barrel trimming was very difficult. I now have several very nice, colorful pieces of firewood. I was trying slimline pens and drilling this wood with a 7mm bradpoint drill was a real treat. I'd dwell right at the beginning for about 5-10 seconds basically using it as a center drill and, even though my cuts were only 1/32"-1/16" deep, it would still walk on me. I'd start off on one side dead center and by the time the drill came out the other side there couldn't have been more the 3/16" wall thickness.
My other problem was barrel trimming. I seems that almost any kind of force would cause the laminates to pull about, causing this operation to take quite some time. I was thinking about sanding the ends down to about 1/8" from the tubes and then using the tedious process of barrel trimming. Any suggestions on both these items and problems.
