Duplicating A Turned Blank - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 02-04-2019, 08:53 PM   #11 (permalink)
Photos: 37
Default
How about a duplicator like the ones from PSI?
https://www.pennstateind.com/mm5/mer...the+duplicator
__________________
Regards,
Mike
Penultimate is offline   Reply With Quote Top
Old 02-04-2019, 10:10 PM   #12 (permalink)
Photos: 0
Default
Quote:
Originally Posted by donstephan View Post
As you noted, tedious and time consuming to make a profile to match a turned item. So draw out the profile first, glue to xray film or whatever and cut out, the turn all 5 to the profile.
Not that time consuming, Block both ends equally and run a pencil standing at 90 degrees to the profile. I done multiple ballusters for doll houses several times, when they are only 1.5 inches long, a mistake stands out like a flashlight at night. But I used that as a guide to cut plexiglas for a homemade duplicator.
For a treehouse, I turned ballusters for the stair case using the same system, these were 2x2s that 2.5 feet long. The customer brought a picture, together we turned one, then I made a pattern. Then for a couple of days I turned the rest of them. As long as the guide point moves in the same plane as the cutter and the guide stays on the profile, they will match up.
I considered these jobs as easy money, because I also charged for making the pattern and the duplicator. Half the dollars up front, the balance on completion.
dogcatcher is online now   Reply With Quote Top
Old 02-04-2019, 10:23 PM   #13 (permalink)
Photos: 0
Default
That one is a knock of the Ankar duplicator, it was designed for miniature makers, as in small scale dollhouses. It works, but for just a onetime deal, it is easy and cheaper to make one following some plan on Google. If you want to have fun with miniatures, search "Tom Walden miniatures", warning that can be a bottomless pit. both money and time.
Advertisement
Old 02-04-2019, 10:42 PM   #14 (permalink)
KLJ
Photos: 29
Default
I have used a storyboard to mark my high and low points. Calipers for measuring them.
Hold the caliper behind the blank where a low point will be then turn it till the caliper or open end wrench slips over the blank, then turn your high point to match that. Do same for the lows and connect the two. The needle like profile transfer things can be somewhat helpful when you get it close. If you are the one turning the first one remember you have to make others to match it and don't make it harder on yourself than you need to. I made this sound much harder than it is to do, it is a lot easier than it seems like.
KLJ is offline   Reply With Quote Top
Old 02-05-2019, 03:23 AM   #15 (permalink)
Photos: 4
Default
My sister-in-law once showed me her set of beautiful set of hand blown wine goblets. She told me she hated them because if you looked closely, each one was slightly different. Indeed they were. Dinner was later served with very ordinary wine glasses that could have come from anywhere, but at least every one was completely identical.
__________________
"In theory, there's no difference between theory and practice. In practice, there is."-Yogi Berra
Shock me is offline   Reply With Quote Top
Old 02-09-2019, 01:20 PM   #16 (permalink)
Photos: 0
Default
subscribed, this seems like a very interesting thread
bertha is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
