bwebb
I finally got my dual twist round top pen together, now the twist mechanism is extremely hard to twist in either direction. What did I do wrong?
Originally posted by bwebb
<br />I finally got my dual twist round top pen together, now the twist mechanism is extremely hard to twist in either direction. What did I do wrong?
(3) when the CB was pressed on the tube collapsed a little and is binding on the mechanism. These double twist americanas and euros are very sensitive to the three things I just mentioned. NOTE: Before the two halves are pressed together and before the finial is installed, be sure the transmission will slide COMPLETELY through the upper pen half. It must slide through freely and completely...no restrictions. If not, use something to clean out the glue or use a drill bit or punch or something to expand the tube a little so the transmission will pass through easily.
Originally posted by PatLawson
<br />Ooops! Didn't see Don's message before I posted mine.
So.....what Don said. Plus don't worry about disassembling it the way I mentioned, (I've done it many times - it's the punishment for not remembering to check the brass tube before assembling...),
Good luck on your fix!
Pat L.
Originally posted by its_virgil
<br />I had this same problem when I first started turning pens and was so frustrated and guess who came to my rescue? Thanks Pat! It was Pat, so my solution was actually Pat's solution...
