ncboyntx
I tried drilling a 7mm hole in a 30-30 shell casing and had problems getting the hole centered. You would think the drill would line up centered with the cap hole but mine didn't. It is off centered enough to make a difference when joining the upper barrel. I used a drill press vise with a V shape notch to hold the casing, same as I do my wood blanks. Is there a better way to drill these?
TIA
TIA
