Drilling on lathe and blank size - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 10-30-2017, 11:05 AM   #1 (permalink)
Woodchipper's Avatar
Photos: 1
Default Drilling on lathe and blank size
After watching the video on another thread, I had stated that I drilled some hardwood on the lathe. The label said 3/4X3/4X36. However, the blanks were a bit loose in the jaws. This is a Supernova 2 lathe with the long pen jaws. As a result, the holes were oversize. I marked them as 7 mm+ for future use. I got curious and tried some acrylic blanks that were drilled and had the tube inserted. These were from Woodcraft- I have a store close to my home. The jaws were turned down as far as they would go. A couple of blanks slid in with no trouble, indicating a loose fit. Others did not fit and would have required loosening the jaws a bit for the blank to fit snug. Obviously, not all blanks are what is indicated. What is your experience here? What can be done besides drilling on the drill press? I have concluded that when I cut my own blanks, the dimensions will be over 3/4 square to fit the chuck jaws.
Thanks in advance.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 10-30-2017, 11:31 AM   #2 (permalink)
gtriever's Avatar
Photos: 3
Default
One of the first things I bought was PSI's Dedicated Pen Blank Drilling Chuck, and I've been very happy with it. It'll handle blanks up to 1 inch. Just out of curiosity, what is the model number of the Nova jaw set?
gtriever is offline   Reply With Quote Top
Old 10-30-2017, 11:31 AM   #3 (permalink)
Photos: 21
Default
I can tell you this... I have made some beautiful pens with some itsy bitty blanks. When I buy expensive wood I try to make it last and turn as little as possible into sawdust. For me the answer would be to find a better way to hold them on the lathe rather than require larger blanks for everything. I've gotten to where I'll cut some wood just over the bushing size because I'm confident I'll drill it straight. Of course, I'm a neanderthal and still use my drill press and a square...
McKenzie Penworks is offline   Reply With Quote Top
Advertisement
Old 10-30-2017, 12:05 PM   #4 (permalink)
Photos: 1
Default
The pen jaw number is 6034, l isted as the Nova Pen Plus Accessory Jaw. It seems that all my acrylic blanks are not exactly 3/4x3/4. The chuck is a Supernova2 chuck, not lathe as I stated earlier.
__________________
Old 10-30-2017, 12:51 PM   #5 (permalink)
KenV's Avatar
Photos: 0
Default
Checked mine on a SN2 and the calipers reads 0.470 flat to flat with the jaws closed. Have used 1/2 inch blanks with success (corian).
Sounds like a opportunity to take the SN2 apart and check the gear and slides.
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 10-30-2017, 01:41 PM   #6 (permalink)
Photos: 1
Default
KenV, I just checked the chuck and this is what I saw. I'm going to call the part that screws to the chuck body the base. The edges of the four jaws/bases are touching adn can't tighten down anymore. I sent Teknova an email to see what the minimum size of a square would be. Hope I hear from them.
__________________
Old 10-30-2017, 02:16 PM   #7 (permalink)
Photos: 0
Default
you have something wrong there. the spec states:
Sizes:
Square (Contracting) Grip : From 0.3937” up to over 1”. Length of turnings from jaws up to 9”
Rounds (Contracting ) Grip: From under ” (actual: 0.4561”) up to over ”. Length of turnings from jaws up to 10”
Rounds (Expanding) Grip: From 1.37” up to over 2.5”. Length of turnings from jaws, up to 10”
do you have a pic of the jaws on your chuck?
Marcros is offline   Reply With Quote Top
Old 10-30-2017, 04:29 PM   #8 (permalink)
Photos: 1
Default
I'll have to get one later.
Here is what I got from CS-
"No worries, then your jaw range is going to be at 0.394-1.220 when contracting. I have attached our jaw range specification table for future reference as they do differ between different chucks. Please contact us back if you have any additional questions or concerns and we will be more than happy to assist you."
Will print off the chart.
__________________
Old 10-30-2017, 05:49 PM   #9 (permalink)
Photos: 14
Default
What about gripping the edges, not the flat sides ?
__________________
Pierre
Kit less, create more.
Pierre--- is offline   Reply With Quote Top
Old 10-30-2017, 06:22 PM   #10 (permalink)
KenV's Avatar
Photos: 0
Default
John, I have 2 jaws set opposite of each other for Pen Jaws
I have 4 piece PIN jaws.
Do you have two sets of Pen Jaws mounted??
__________________
Ken Vaughan
Related Content
Reply
Bookmarks
Tags
blank , drilling , lathe , size
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
