jeffnreno
Hi All
I was getting ready to go buy a new drill press - mine never seems to drill down the center of the blank and the quill length is to short for many pens. I was trying to drill some blanks for Presidente (admittedly the blanks were a little undersized) pen blanks and ruined a few that I had glued up. Frustration.
Then I remembered seeing here about drilling on the lathe so I decided to give it a try. Drilled directly thru the center of all blanks that I tried. It took a little longer then the drill press but great results. I will add that I found by drilling a pilot hole with a 1/4" bit made it much easier to drill out with the large bit needed.
I guess the end result is I allready had the equipment to drill on the lathe so I saved a few hundred bucks I would have spent on a drill press - so hooray I can now buy more pen stuff. I went straight to Artstuff and ordered some additional casting material.
Have a great day - and if you need to drill some blanks give the lathe a try.
