I drill on the lathe. I round my blanks to cylinders before drilling and make sure they are centered in my chuck. I center drill the blank about 1/2 inch or so with a small center drill. Then I switch that out with the bit I am going to use for the pen. 90% of the time it comes out just fine. However, once in a while it seems something forces the bit to the side slightly and the exit hole is not on center, so I essentially drilled at an angle through the blank. Happens on longer blanks I drill, most of which are closed end so I don't really know the hole is angled till I chuck it up on a closed end mandrel and collet chuck. Questions I have:
1. Could it be a hard spot or soft spot in the wood causing it? If I drilled to whatever depth I am going with a smaller bit first, would that eliminate it. I use both the regular bits and the brad points, which doesn't seem to affect it either way. Anyway, any suggestions to minimize this or do others have the same problem on an occassional blank?
I started thinking through all that I do to make pen and theoretically it is very simple. However, in reality, the execution of the simpliest of things can be difficult, at least for me.
Just looking for feedback.
