SoloWorx
Hello fundamental question about drilling. I've noticed when drilling some wood blanks but mostly acrylic blanks when I'm done the hole is larger than the diameter of the drillbit. This is usually larger where the drillbit enters and smaller where it exits the black . I've noticed that during drilling I get vibration at times and when I extract the bit large drill shavings come with the bit. These are built up in the grooves of the bit. I take several sequences drilling into the blank and don't do it in a single plunge. Quite frankly I go back and forth many times in and out. I clean the drillbit off after every extraction from the blank while running I use a brush. This mostly occurs on the larger sized drillbits say larger than 3/8".
Is this due to the build up on the drillbit while drilling? I do not appear to have run out on the bit or lash in my drillpress. Should I drill up to the final Bore diameter in sequence? Or should I drill the final size one time and be done?
This causes me when gluing to build up additional layers of glue between the Tube and the blank.
