Drilling Blanls
marshall1225
NJ
Can I use a fractional drill bit to drill the blank for a Big Ben Cigar pen or is the tolerance critical. It calls for I believe a 10mm drill.
mredburn
IAP Activities Manager
Staff member
Fort Myers FL
You can always do a test hole in a piece of scrap. Most of the tubes are smaller than the drill sizes that are called for. A lot of us measure the tube and pick the drill bit that will do the job best. A larger hole is needed for back painting the blank or if you paint the tubes.
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
3/8" = 9.525 mm
13/32" = 10.319 mm
Of the two, the 13/32" would be the better choice as Dick noted. However, if you only have the 3/8" on hand, I would suggest that you test drill a scrap piece of wood and see how well the tube fits. You might have to ream it out slightly with a round file or sandpaper.
An index set of drill bits is a worthwhile investment for pen turning. Harbor Freight has this set on sale right now
115 Pc High Speed Steel Drill Bit Set with Index
ed4copies
Local Chapter Manager
Racine, WI, USA.
The cigar kit (WCO145) originally called out a 25/64--I made hundreds using that dimension. I think the Big Ben is the same tube, but I am not certain.
