Drilling blanks on the lathe
Rcd567
Glenwood, Iowa, USA.
I've got a nova midi and a drill bit accesory. I know the drill bit goes in the tail end, but what do you hold the blank with? Is there a set of jaws I should be using? Thanks for your time.
thewishman
Reynoldsburg, Ohio, USA.
I just use the stock jaws that came with the Nova midi. I put the blank in so that the corners of the blank are in the center of each jaw. You could be even more accurate by turning the blank round and then drilling.
Skye
Rock Hill, SC
Headstock (jaws):
Tailstock (Jacobs #2MT):
