drillbit question
cacardon
Fallbrook CA.
good day all, I have a quick question. I am needing a 12.5mm bit for a pen kit. I don't have one I could drive and get one, but the language barrier is tough to over come here. Will a 1/2 work? I know its .2mm bigger but will that make that much of a difference?
as always
thank you and Semper Fi
Edgar
New Member Advocate
Staff member
Alvin, TX 77511
Another way to look at it is that the best English equivalent to 12.5 mm is a 0.492"' bit, so a 1/2"' bit is .008" larger than ideal.
It will likely work ok, but to be sure, you should drill a hole into some scrap wood with the 1/2" bit and test fit your tubes befor drilling a real blank.
NittanyLion
State College PA
I use a 1/2 bit in place of 12.5mm bits only because I cannot find a high quality 12.5mm bit. Just make sure your drill press/lathe has no drift in it and it drills true. I also use epoxy for gluing my tubes. I would not want to use CA or any other glue with the extra room. Hope this helps!
mutley
31/64 is just under, 0.484 vs .492 or 12.3 vs 12.5. You can probably make that work quite easily depending on the glue used to set the tube.
randyrls
Harrisburg, PA 17112
Charles; Try the smaller bit first. Try to fit the tube and see if it is large enough. I always do this experiment to "try" the fit before drilling a bunch of blanks. There are several drill bit charts in the Library and on the net that have decimal size comparisons.
