Drill Press quill travel too short
blodal
Arlington, TX, USA.
My drill press is a Delta bench top. The quill travel is 2 3/8 in. The first blank I tried to drill is 2 3/8 in long. I cannot drill completely through it.
What is the best way to handle this? I moved the blank up in my jig and reclamped it with the bit in place, then started the drill and finished the hole. Are most blanks this long, and will I continue to have this problem?
Looking forward to your answers.
Thanks,
Dario
Austin, TX, USA.
I bought the same DP knowing full well about this issue...but we have to deal with what we can afford. Budget is a real issue for some [:D].
At any rate, I do the same...after drilling to the quill's max capacity, I raise the blank a bit and finish it off.
Only solution to avoid this issue is to upgrade DP.
alamocdc
San Antonio, Texas, USA.
Bill, some are even longer so it becomes even more of a problem. I had the same issue with my Ryobi, so I bought a floor model with a 3 1/4" stroke. I'm much happier now.
JimGo
North Wales, PA
Other options are to insert something under the vise to raise it a bit, and loosen the bit and allow it to drop some.
terrymiller
Germany
The few times that I have encountered this I turned the drill press off at the bottom of the stroke loosen the clamp holding the wood blank. Then I let the drill press raise up about an inch or so then hold it in that position and
re-clamp the wood and continue drilling. I found that with this method the drill bit grips the wood and ensures that the hole is perfectly straight and no wandering.
gerryr
Billings, MT, USA.
That reminds me of a joke about a male singer in a bar who's approached by one of the female patrons who asks. "Are you a tenor?" To which he replied..................[}:)]
Randy_
Dallas suburb, Texas, USA.
The easiest thing to do is to have a small piece of 3/4" plywood available and when you reach the end of the quill travel, turn the DP off and put the piece of wood under your jig. Depending on your setup, loosening the drill bit or moving the blank in the jig risk losing registration and getting a hole that is not straight or round.
redfishsc
North Charleston , SC
I may get ostracized for saying this but this is where the Shopsmith shines-- in drill press mode it can drill out any pen blank I've encountered! Not that it's worth buying a $1000 used machine, but if you happen to find a cheapie or already got one...
hazegry
Virginia Beach, Va, USA.
I dont know if you want to upgrade or not but the rikon 34-140 radial drill press is one heck of a machine for 159 bucks and it has 3and1/8 inches of travel. you can get by with what you have and upgrade later but if you do decide to upgrade shop around and definetly look at the rikon.
jthompson1995
Parkville, Maryland, USA.
I used to have a shopsmith and the long quill travel was nice, but it would not drill a straight hole for all that I tried. I just got a shopfox benchtop oscillating drill press that has 3 1/4" travel and love it., straight every time and it converts to an oscillating drum sander. I did see an article in a recent wood magazine that showed a simple jig that allowed for easily raising the blank to drill all the way through.
Jason Thompson
Parkville, MD
