Which Drill press to get?
Dario
Austin, TX, USA.
My old Craftsman tabletop drillpress which uses a hand drill just broke and I need a replacement. It can still be fixed but I am tired of wasted blanks due to wandering drill bit ;).
I want a small but accurate setup...which (brand/model) can you recommend?
Thank you,
its_virgil
Wichita Falls, TX, USA.
Just be sure the quill travel is adequate to drill a blank without having to stop and raise the table and make a second pass on the same blank. My first table top drill press had only a 2" quill travel and drilling blanks, while not a great deterrant, was quite annoying.
Do a good turn daily!
Don
Originally posted by Dario
<br />My old Craftsman tabletop drillpress which uses a hand drill just broke and I need a replacement. It can still be fixed but I am tired of wasted blanks due to wandering drill bit ;).
Thank you,
Old Griz
Passed Away Oct 4, 2013
Hagerstown, MD, USA.
Dario, I have a Delta 350VS table top.. I love it and the throw is adequate for anything I make.. and the variable speed feature means not having to change the belts everytime I need to make an adjustment... A real sweet machine... not the cheapest of the bunch but well worth the price..
In fact if you don't mind a factory refurb (and I don't) here is a great deal on one..
http://www.cpowoodworking.com/entire_selection/dp350r.html only $179.99+$30 shipping, list is $277.00
I have purchase from this outfit before and been very happy....
Dario
Austin, TX, USA.
Tom,
I am afraid that is way over the budget. I'll check the Ryobi and even the HF version. Else I might have to repair my old junker DP! Sigh.
esheffield
Christiansburg, VA, USA.
I have the little HF 5 speed / 8" drill press. I've had it for a few years and they don't seem to have the exact one anymore, but I think 44506 is the newer version of the same thing. But it only has 2" stroke which is too short for most pen blanks. Plus mine has too much play in the shaft. I've noticed a LOT of the 8" / 5 speed models, regardless of brand, are virtually identical to each other. If I were looking for a DP right now, I'd be looking for a 3" stroke at least as my main feature.
Dario
Austin, TX, USA.
I agree with the quill travel being very annoying...I have that problem now [:(!] and is indeed very high in priority like shaft play.
I'll check HD and Lowe's the next few weeks so I'll get some ideas (price and quality wise).
Thank for the input guys!!!
DCBluesman
Passed Away Mar 3, 2016
WOODBRIDGE, VIRGINIA
I'm with Coach on this one. I have the Ryobi Model DP120. It's often on sale at Home Depot or Lowe's for $119. It has 12 speeds and a 3-1/8" stroke. If you get this model, take the time to REALLY square everything up and you won't have a problem. I can drill the 15/32" hold for a Baron through a 5/8" square. You can't ask for much more than that for the price!
Scottydont
Edmonds, WA, USA.
I Just sold my Ryobi 12". I am looking at the Grizzly G7945 5 speed bench top radial drill press. Any feedback?
dubdrvrkev
Gilbert, AZ, USA.
Like most have said, buy the most travel you can afford. I still dont have one either but I wont buy one with less than 3"+ inches of travel. I get spoiled at work with our old rockwell with 6" travel and its benchtop. I am going to look at the ryobi, but will probably end up with a bigger grizzly.
Dario
Austin, TX, USA.
I guess I can hold off and...I probably will eventually afford a better drill press [:D]
Comparing these online, all of them have 3-1/4" spindle travel. ShopFox looks very promising [:I].
Grizzly G7943 3/4 Hp $199
Grizzly G7945 1/2 Hp $169
Shop Fox W1668 3/4 Hp $219
Delta DP350 1/3 Hp $209
Rifleman1776
Mountain Home, Arkansas, USA.
The G7943 is a lot more machine for only about $30.00 more. That is the model I have. I bought the bench top for space saving reasons. Doing it over, I would get the floor model, more versitile. But I am happy with the drill press.
Originally posted by scott m
<br />I Just sold my Ryobi 12". I am looking at the Grizzly G7945 5 speed bench top radial drill press. Any feedback?
woodguy1975
Hickory, NC, USA.
The first DP I had was one of those Ryobis. It had terrific runout for such a small unit. I would buy it again if I was in that market. I sometimes think about buying one to dedicate to pen making so I can leave my monster General open for my bigger stuff. I might have just found a use for that extra base cabinet I have laying around the shop. [:D] Didicated Pen making center!
jdavis
longview, texas, USA.
Everyone has their own opinion. Mine is Delta. We have floor model. It is some twenty years young and still doing us a great job. Be sure you get enough throw at least 4".
Dario
Austin, TX, USA.
My local Shop Fox dealer is offering me the ShopFox W1668 for $194.95 (plus $15.60 tax).
Have anyone have any experience with this DP?
Here is the write up/spec.
"Shop Fox by Woodstock W1668 Oscillating Drill Press. This unit serves as both a regular Drill Presse and Oscillating Spindle Sander. This patented dual-purpose machines come supplied with an oversize hole and reducer rings to match different sanding drums. Just connect to a utility vacuum and sand away. SPECIFICATIONS: Motor: 3/4 H.P. 110V, 1725 R.P.M. Overall height: 38" Spindle travel: 3-1/4" Swing: 13-1/4" Drill chuck: 5/8" Dust port size: 2-1/4" 12 speeds: 250-3,050 R.P.M. Table: Round 12-3/8" Dia. Table swing: 360 degrees Approx. Ship. Weight: 115 lbs. MODEL NO: W1668.
<br />"
Tom McMillan
Washougal, WA, USA.
Yes, Dario!!! That's the drill press I have---have had it for over 2 years, and it is great!!! I got mine on sale then for probably 179, and I haven't checked prices lately. But, I have used the oscillating sander also---both it and the drill press work great. It is heavy.
JimGo
North Wales, PA
looks like a nice little set-up! I like the hand-crank for moving the table; bet that would really help make accurate depth adjustments.
Fangar
Wilton, CA, USA.
That shop fox looks like a nice machine. My Ryobi 12" is very nice as well, but runs about 149.00 at HD. For the extra 30 bucks, the extra 1+ of quill travel offered by the shop fox would be nice. The Ryobi is 2 & 3/8", but is plenty for most pens that I have done.
Cheers
Fangar
wrightal3
Katy, TX, USA.
Dario, I have the Grizzly 7944 which is the floor version of the 7943 & am very happy with it. You may want to check out the comparison table at the link below.
http://www.rd.com/americanwoodworker/toolguide/SS2004_DrillPresses.pdf
ravo
Nampa, ID, USA.
I was planning on the Ryobi too, until I read a report on a test of several where it came in last. I went with the DP350. Variable speed, good quill travel, and little run out. $199 right down town (no shipping).
