Drill Bits Sizes - Page 2 - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 11-08-2017, 08:20 PM   #11 (permalink)
magpens's Avatar
Photos: 49
Default
I use this one. . I guess what you recommend depends on what you get used to yourself.
Drill Size Conversion Table
__________________
Mal
magpens is offline   Reply With Quote Top
Old 11-08-2017, 09:32 PM   #12 (permalink)
Photos: 0
Default
Quote:
Originally Posted by BillyBoy63 View Post
Hello Everyone
I have a question about drill bits
if you have a 27/64 drill bit what would be the equivalent or the same size in mm's
I guess I'm going to have invest in a good pair of calipers
thanks
BillyBoy63
check this out
https://itunes.apple.com/US/app/id1062399336?mt=8
iap Bushing & Tube Reference app
Horspowr89 is offline   Reply With Quote Top
Old 11-09-2017, 06:19 AM   #13 (permalink)
randyrls's Avatar
Photos: 61
Default
William; I have often found that the drill bit specified is the "nearest commonly available" drill bit for the tube, not necessarily the best fit for the tube. I have a complete set of fractional, letter, and number bits and a metric set too. When I do a new kit, I start with an undersized bit and sneak up on the correct size using my drill bit chart. i want a close sliding fit with no play. After I find the correct bit, write down the size on the instructions and it goes in my folder for that pen kit.
Hope this helps....
__________________
Randy S.
~~~~ Add Your Postal Code and Country to the UserCP ~~~~~
Internet Addiction is now an officially recognized mental disorder, I'd go, but they don't have Wi-Fi.
randyrls is offline   Reply With Quote Top
Advertisement
Old 11-09-2017, 08:26 AM   #14 (permalink)
KenV's Avatar
Photos: 0
Default
Drilling for pen tuubes is like horse shoes game. - close counts.
Prices for available low volume drill bits like a 10.7mm or 10.75mm bits is very high. Amazon had prices around $30 for a bit.
Use calipers on the outside of the tube as a starting point for the somewhere close choices.
__________________
Ken Vaughan
Old Apprentice Machinist - learning a new knee in Tucson
KenV is offline   Reply With Quote Top
Old 11-09-2017, 01:42 PM   #15 (permalink)
fernhills's Avatar
Photos: 2
Default
I use the charts and a plastic hole template. The template lets me see how tight or loose the bit is by inserting the actual bit through the hole. Carl
__________________
Carl, Hellertown,Pa
http://www.talltimbers.etsy.com
fernhills is offline   Reply With Quote Top
Old 11-09-2017, 02:41 PM   #16 (permalink)
Rifleman1776's Avatar
Photos: 0
Default
Hello Everyone
thanks
BillyBoy63
Grizzly tools sells a pocket reference book that has table and charts for almost everything. Or, you can just Google the question.
__________________
Frank
Mountain Home, Arkansas
"All animals are equal, but some animals are more equal than others." from Animal Farm by George Orwell
Rifleman1776 is offline   Reply With Quote Top
Old 11-09-2017, 07:53 PM   #17 (permalink)
Beautys_Beast's Avatar
Photos: 0
Default
10.5 is the answer your looking for. It will fit.
Beautys_Beast is offline   Reply With Quote Top
Old 11-15-2017, 02:15 PM   #18 (permalink)
Photos: 0
Default
interesting thread, I also have the same question
mario01 is offline   Reply With Quote Top
Old 11-15-2017, 03:02 PM   #19 (permalink)
Photos: 0
Default
Another thing to keep in mind is that the hole size that you get is very often material dependent. Alumilite, for example will almost always spring back somewhat after machining, although it may take a little bit of time.
I don't know if it's still available, but there used to be a chart basically identical to the one that Mal linked to available as an iPhone app.
Regarding KenV's comment, "Close counts", I couldn't agree more except when you're cutting a cap thread with a .8mm pitch; then that horseshoe had better be a leaner. Victornet sells metric bits from 10.1mm to 13.5mm in .1mm increments for $4.20 to $8.90 depending on size. Not cheap, probably Chinese, but sometimes you need the precision unless you have a boring bar which is probably a better alternative anyway.
My $.02
Bill
bmachin is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Content Copyright © 2003-2016 by Penturners.org, LLC; All Rights Reserved
