Drill bits and reverse painting
Bastrop, Texas
Has anyone used a smaller-than-recommended bit when using reverse-painted blanks? It seems like it would make the whole (hole?) process easier, and allow the tube to fit better without scraping paint off the inside.
Let's hear it!
OKLAHOMAN
Costa Rica
Hope he meant larger, and just had a brain F@&T. like I just had and offered someone $17 when they wanted $70.
Jim Burr
Banned
Reno, Nv
Ok...just wanted to make sure the crack I had for the Raiders game (JUST KIDDING!!!!) hadn't dulled by pen sensibility.
tim self
Atoka, Oklahoma
I do not have that problem. If/when I need to reverse paint, I simply sand the inside of the blank. It will enlarge the hole slightly and remove any bit marks inside the blank.
Dai Sensei
Gold Coast Queensland Australia
I initially sanded the inside, but found I tended to sand unevenly, so ended up to big in some areas. Now I use an adjustable reamer that suits the hole, I have 8 of them that cover the tubes I use.
bwftex
Texas
If you use enamel model paints like Testors and give the blank several good coats and a day to dry it shouldn't be a problem. Sand the outside edge of the tube to give it some tapper so it won't cut into the paint if the fit gets a little tight.
