Drill, baby. Drill! 5 inches? - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 12-02-2009, 05:03 PM   #1 (permalink)
WildcatHollow's Avatar
Photos: 15
Default Drill, baby. Drill! 5 inches?
What's the best way to cleanly and accurately drill a blank for a 5 inch brass tube when my drill press only has 3 inches worth of downward reach?
I thought about flipping the blank, but realized that any minor change in any one of the adjustment variables would mean the two holes would be slightly off.
Other than ordering pre-drilled blanks, are there DIY options?
Thank you for your help.
Regards,
t.
WildcatHollow is offline   Reply With Quote Top
Old 12-02-2009, 05:23 PM   #2 (permalink)
Rmartin's Avatar
Photos: 4
Default
I have had the same issue. I will drill as deep as possible, and then raise my drill press bed. It takes time, but it can be done. Sometimes you have to lower the bed to clean the debris, and then lower and drill some more.
Also, think about segmenting bands which can be drilled seperately and then glued as one on the blank.
__________________
Richard
http://fcfpens.com/index.html
FountainCityFurniture.com
Rmartin is offline   Reply With Quote Top
Old 12-02-2009, 05:24 PM   #3 (permalink)
Local Chapter Manager
ed4copies's Avatar
Photos: 27
Default
If you have a 5" bit, just put something under your blank (2x4) to raise it on the bit.
__________________
Ed Brown
ed4copies is offline   Reply With Quote Top
Advertisement
Old 12-02-2009, 05:28 PM   #4 (permalink)
Photos: 5
Default
Drill on the lathe
Manny is offline   Reply With Quote Top
Old 12-03-2009, 07:29 AM   #5 (permalink)
DurocShark's Avatar
Photos: 18
Default
Quote:
Originally Posted by Manny View Post
Drill on the lathe
My lathe doesn't have 5" of tailstock travel. So I end up in the same boat. The difference is I can just loosen the tailstock, retract the quill, and slide it right in and go again. I've gotten pretty quick. . .
__________________
Don - In a Mickey Mouse town
DurocShark is offline   Reply With Quote Top
Old 12-03-2009, 10:14 AM   #6 (permalink)
dow
dow's Avatar
Photos: 17
Default
Quote:
Neither does mine, so I drill to the amount of travel that I do have, and then spin the chuck back into the tailstock and move the tailstock towards the end of the blank and drill further in. Works like a charm. I drilled a BOW blank for a long click last night, as a matter of fact.
__________________
Nothing is foolproof to a sufficiently motivated fool.
dow is offline   Reply With Quote Top
Old 12-03-2009, 10:21 AM   #7 (permalink)
Photos: 0
Default
And mine also only has a 3" plunge as well. Simply just do the 2x4 thing raising the blank up into the bit.
Or raise the bed as others have said.
Chief Hill is offline   Reply With Quote Top
Old 12-03-2009, 11:19 AM   #8 (permalink)
mrcook4570's Avatar
Photos: 0
Default
The holes in the pre-drilled blanks are slightly off set because they are drilled from each end (at least the ones I have seen).
__________________
Stan in WV
Laser Engraving
http://www.mestaridesigns.com/turners
http://www.engravingcave.com
mrcook4570 is offline   Reply With Quote Top
Old 12-03-2009, 11:22 AM   #9 (permalink)
ed4copies's Avatar
Photos: 27
Default
Wow, if THIS is difficult, wait until you do your first peppermill!!
__________________
Ed Brown
Related Content
Reply
Bookmarks
Tags
blank , drill , drilling , large , long
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
