The dreaded gap between tube and blank - International Association of Penturners
Pens for Service Members
Support The IAP
Go Back   International Association of Penturners > Community Forums > Penturning
  Forgot Password
Penturning General penturning discussions not specifically addressed in one of the specialty forums.
Welcome to penturners.org!
Reply
Old 01-19-2019, 09:33 AM   #1 (permalink)
Photos: 0
Default The dreaded gap between tube and blank
Hey all,
After squaring a hybrid blank recently I noticed a drilling issue on one end, a sliver of a crescent moon that looked like this:
The gap looks hollow but is actually filled with epoxy; nevertheless it meets the outer diameter of the bushing I intend to use. I did paint both tube and hole. I donít know how far along the tube the gap is, but it just looks like a blow up waiting to happen. Itís a nice blank and Iíd like to salvage it if possible.
The only remedy I can think of is to use a parting tool to turn down the affected region to the tube and glue on a segmented end cap (maybe on both sides), though that will be hard to make look good.
As the Dude said, maybe my thinking has become too uptight, man. Anyway, I appreciate any thoughts, suggestions you might have.
Russ
Sly Dog is offline   Reply With Quote Top
Old 01-19-2019, 09:41 AM   #2 (permalink)
jttheclockman's Avatar
Photos: 104
Default
Yep no way out. Use a oops band and will hide it or use a larger kit if possible. Could also do a bulbous looking turned blank. Good luck.
__________________
John T.
My Photo Album
jttheclockman is offline   Reply With Quote Top
Old 01-19-2019, 10:47 AM   #3 (permalink)
Photos: 0
Default
If it is filled with epoxy all the way through you shouldn't worry about a blow out if you take light cuts with a sharp tool. Once I turned it to size I'd see how it looks and if I wasn't happy turn it down to below size. Then take shavings and backfill it with them and ca glue. Let it dry and then turn it back down to the appropriate size. Its risky but it might work?
Gersh is offline   Reply With Quote Top
Advertisement
Old 01-19-2019, 11:03 AM   #4 (permalink)
mark james's Avatar
Photos: 498
Default
Quote:
Originally Posted by Sly Dog View Post
Hey all,
Attachment 184142
Russ
Check with calipers the OD of the components, there may be enough timber to be OK to turn.
And, using end caps is not too tough, and can look quite nice with some attention to contrasting materials. I simply us any available stick/scrap wood of the approximate dimension wanted (eg, 1/8", 1/4", etc) to get the two ends equal, part it down to the tube on both ends, drill the tube holes in the end cap material and you are good to go.
__________________
Check out the
IAP Collection
The IAP Collection is a permanent collection of pens
that has been established from the
IAP Membership explicitly for the purpose of
public display, preservation and inspiration.
mark james is offline   Reply With Quote Top
Old 01-19-2019, 11:09 AM   #5 (permalink)
skiprat's Avatar
Photos: 227
Default
I'm afraid I have to disagree with my fellow penturners. To me it looks like the hole is simply too big for the tube...ie; wrong drill size used.
I honestly don't think an oops band will help.
I'd see if the tube matches another fatter kit or take a chance and just go for it, you may be lucky....if it blows, it blows.
__________________
www.skiprat-pens.com
skiprat is offline   Reply With Quote Top
Old 01-19-2019, 11:27 AM   #6 (permalink)
gtriever's Avatar
Photos: 3
Default
I've had that happen when the drill is started off center ; the starter hole end becomes elongated. I've compensated on occasion by leaving the blank long and gluing the tube in past the elongated part, or if the gap isn't extreme by filling it with CA. But looking at the photo, in this case I see no options other than making a new blank or using oops bands.
__________________
Pull up a chair and visit a while :
https://www.facebook.com/thestatepen/
gtriever is offline   Reply With Quote Top
Old 01-19-2019, 11:31 AM   #7 (permalink)
mecompco's Avatar
Photos: 10
Default
I'm not optimistic, but I would turn it. At worst, you can just turn off the timber and re-use the tube (assuming you've not overly shortened it while squaring). I've gotten away with a sloppy drill job a few times, a couple times, not so much. How does the other end look? I'm not sure it's the wrong sized hole--I've had bits follow the grain in wooden blanks and produce an exit hole that's too big, even having center-drilled first and I drill on my machinist's lathe so it's pretty rigid.
__________________
Michael
Fairfield, Maine
mecompco is offline   Reply With Quote Top
Old 01-19-2019, 11:56 AM   #8 (permalink)
Photos: 0
Default
Is this an ongoing issue you have or just a one-off thing? It does look like a nice hybrid blank. I'd take the same size tube and while holding it butted up against the end of the blank backfill it with dust and CA. Would avoid the barrel trimmer especially since it looks like a hybrid blank and a barrel trimmer just loves to eat hybrids for dinner. Opt for the disc sander, then just turn it. As someone said, if it blows, it blows but you should be fine if the rest of the tube is firmly secured in the blank.
__________________
Andy - Seattle
ramaroodle is offline   Reply With Quote Top
Old 01-19-2019, 12:02 PM   #9 (permalink)
Woodchipper's Avatar
Photos: 1
Default
I had that happen a couple of times. Can't really say what caused it. Here's what I did- I got a thin needle and put the point in the space between the tube and blank. I ran a couple of drops of thin CA down the needle and into the space. Tap the blank lightly to get the CA down even more. Once, I had to do this twice to fill the gap.
__________________
To err is human; To really mess it up, you need a computer.
Woodchipper is offline   Reply With Quote Top
Old 01-19-2019, 12:34 PM   #10 (permalink)
TonyL's Avatar
Photos: 6
Default
1 or 2 out 20 barrels, I will get that whether I drill on a press or lathe, whether I use a new/sharpened bit, drill and 1/4" at a time or 3/4 at a time. I might just stink at drilling.
My only "somewhat successful" work-around is to try to keep it centered when gluing...and that doesn't work all of the time.
I also think the hole is too big versus OOO.
What is a oops ring?
__________________
Am I not destroying my enemies when I make friends of them? Abraham Lincoln
Peace,
Tony
Member of Local IAP Georgia Chapter meets quarterly in Roswell, GA
TonyL is offline   Reply With Quote Top
Related Content
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
