pmpartain
On the last several pens that I have assembled, I am having problems with the transmission properly seating into the finial. I've had the problem with the perfect fit and the cigar. The finial doesn't grip the transmission enough to unscrew the pen and change the ink cartridge. You can easily pull the two halves apart. I can see two possible fixes. Use CA to give a little stick, or shorten the top tube to allow the finial to press farther onto the transmission. I tried the CA and promptly ruined a cigar pen. Froze up the transmission solid. I'm not excited about trying that again, so I thought I'd ask if anyone else has experienced similar problems.
Thanks as always
Thanks as always
