penbros
i dont know if this has already been tried by anyone but it works well for me. its a block of wood that protects the point of the live center but supports the mandrel. heres how to make it.
Pure simplicity
1. mark the centers on a short 3 inch 1.5 inch square block of poplar
and mount between centers.
2. turn it to a cylinder (keep it 1.5 inces in diameter)
3. take it off the lathe and go to the drill press. on only 1 end of the cylinder drill a hole in the center (diameter or your mandrel)1/2 " deep.
4. put your mandrel on the lathe how you narmally would when u turn a pen . mount the cylinder so the mandrel goes into the 1/2" inch deep hole and put the live center up to the end of the block in the center.
5. turn back to true
to use put the mandrel in to deep the hole and put the tailstock up to the end and into the small hole created by the point in the building process then tighten a half turn to keep the mandrel steadt but not bend it
hope i helped anyone out
Pure simplicity
