THarvey
I have a Sierra, with a damaged finish. What is the safest way to disassemble this pen without damaging the cap or transmission?
Thanks.
Thanks.
First try a small hammer; if that doesn't work, get a bigger hammer! :biggrin:
Tim,
I am not sure if I understand it completely as it is written above, but the Sierra cap comes off with a twist and the transmission stays on the nib end. I use a HF punch to tap the cap/clip off. I have done this quite a few times for refinishing or retouching a Sierra blank. I use some of the rubber webbing mat that is used to hold sanding pieces or holding small boards for routing - these matts make great grips for holding the blank while tapping the end off with the punch.
Tim,
Another general disassembly trick that I've learned is to put a piece of folded up paper towel under the clip so that the clip doesn't dig into the finish on its way out.
