A Dilemma
Well I got myself in a pickle. First let me say I have started up making pens again after about a year layoff. I found an old segmented blank I made up about 4 or 5 years ago. I tried this blank once before but blew it up but I learned from my mistakes as we all do as we go through this stuff. Well I must have constructed the blank again back then but never cast it. I am thinking of taking another crack at it.
But here is my dilemma. I have NOOOOOO idea what kit I built this on.:rolleyes: I looked through all my kits that I usually use. I also have some I never used but nothing matches the sizes of the tubes. I started looking through the charts in the library but so far no luck and boy there is alot of kits.
So I thought maybe someone here has either made a cheat sheet over the years and matched kits according to size in some shape or form, Or can recognize the dimensions of these tubes.
This is a 2 piece kit more than likely a rollerball because that is about all I make. The small barrel which is the Cap is (these measurements are within a click or 2 because tough to get true readings with the work on them)
Cap:
12.28mm X 47.57mm
or
.482" X 1.879"
Lower tube
10.18mm X 57.17mm
or
.401" X 2.251"
What is throwing me off is the lower tube is so much longer than kits I usually use. I am assuming I chose this kit because it has substantial meat left when turned down to accommodate the casting.
So I am reaching out to the masses in hopes I can solve this. Thanks in advance and if I happen to stumble on it in the mean time I will report back. :):)
mbroberg
Columbus, OH
Majestic Jr. RB / FP specs are pretty close, except for the length of the lower tube.
Upper tube:
.483 X 1.88
Lower tube:
.400 X 2.03
Upper tube:
.483 X 1.88
Lower tube:
.400 X 2.03
That was the exact kit I thought because I am using them for other things right now and I put the cap next to one of those and looked spot on but when I put the lower tube next to one not even close. Still a puzzle. Thanks for looking.
cdwrrtx
Round Rock, TX
The ID of the tubes is the critical measurement. A two-piece rollerball kit with the proper inside diameters could still work if the tubes are too long. Cap will be just a bit extended and you can extend the body using a spacer to properly position the refill/spring. So you can have a custom XL version!
JohnU
Ottawa, Illinois
The Jr. Aaron is slightly longer than the regular Jr's. but the same diameter. It just has a longer spring. Now when I order replacement Jr tubes, they all come with the longer lower tube. I was told they are phasing out the original shorter lower tube.
Dehn0045
US
Here are a few that are close:
Kojent Twist Cap BP (1.90/2.24)
Atrax RB/FP (1.90/2.19)
Aaron Jr (1.89/2.17)
George Jr (1.89/2.17)
Hancock (1.86/2.27)
Not sure you'll be able to find a Hancock (Lazerlinez), the Atrax looks like the next best option in my opinion...
magpens
Canada
The lower tube length of 2.251" ...
The Lazerlinez Hancock, according to Home Page table is 2.27" long ...
I have run into this longer than normal length on a couple of prev. occasions. . But, of course, I would not know if this is a kit you might have considered at one time.
mecompco
Fairfield, Maine
My thought was the same as Sam's--Atrax (or Triton--same platform with a little more bling). That seems pretty close to their 10.5 and 12.5mm tubes. Obviously, the tube lengths don't need to be exact for this application.
I have none of the above mentioned kits so know they are out except the TRiton. I will check that one. Thanks. :):)
Well I think I found it and would not have guessed and actually do not remember buying these and that is why it never rung a bell.
But the kit is a Lazerline kit called Desire. I believe unavailable any more. Thanks for all those who tried to help. Another reason I never saw in the library. He does not give dimensions for his kits. :):)
magpens
Canada
Ha ! . So it IS a Lazerlinez kit. . I believe they are good products, but, as you say, the necessary detailed info is not so readily available.
And for the Desire kit, I notice that the lower tube "critical" length is missing from the tabulated data on the IAP website.
I have some Lazerlinez kits in my stash. . In some cases, the baggies are not even labelled with kit names. . But I have kept them in a separate box.
Curly
Saskatoon SK., Canada.
I don't suppose it would help if you looked though your pictures from 2+ years ago to see what you were making at the time? Maybe that will ring a bell.
Never mind. I think and type too slow.
Yes Mal it is. There must have been some sale or something going on back then that made me buy that kit. Only have a couple but I did mark the bags because as you mentioned no other name on them. Have gotten into that habit and glad I did back then. I just looked through a bunch of odd ball kits that I either bought from some people here as they were selling out or just kits I have not thought of in a long while. What triggered it was the mention of the Triton kit. I have 2 sets of blanks made up for those too that I was suppose to make and maybe someday will spin those too. I made those up about the same time. I labeled the blanks so know what they are but this one was a head scratcher because I had no other details. I measured the tubes on the other kit I have and they are close to what I mentioned but not exact because I could not get my calipers to lay just right on the tubes so I was ball parking it but not bad. :):)
I will see what I can do with it now but happy I know what kit it is in case I get it spun well. :):):)
Would not have helped Pete. I never made that kit before. It had to be some sale or something going on when I bought them. The only bushings I have are between center bushings for it so at least I have that. :):)
