KC
Different than the threads...which I've also noticed. I think I bought (and made) 20 Jr Statesman II, and 30 Jr Gents. On probably half of the Jr Statesman, the top/clip assembly won't tighten down to where the clip won't rotate quite freely When put together before assembly, the clip appears to be fully 'seated' against the top...and I'm pressing them with as much as I've got. If I can get it tight enough where you have to TRY to rotate the clip it doesn't bother me too much...but some of them will spin with incidental contact. The top doesn't feel 'tight' going in...it just doesn't ever 'grab' and hold the clip in place. OTOH, some of the tops I can press in with finger pressure (these I spot glue)...so I wonder if there's a machining issue with that piece?? Didn't notice a problem with any of the Jr Gents. I'm not using a barrel trimmer on these, so I'm not reaming out the tube accidentally....
?? KC
?? KC
