avbill
I just received some different kits. the kits are wall Street II & wall street III. CAn anyone explain the different between the two.
thank you
thank you
The Wall street IIIs (or Sierra Vista) are better for imbedding material into a casting such as watch parts due to the thicker wall.Outer diameters will be different. Wall street III (aka sierra vista) has a larger outer diameter, thus greater wall thickness since the tubes are the same.
