Denatured alcohol or Acetone
crabcreekind
Eugene, Oregon
I just recently got all the supplies to start doing a CA finish(thanks to my bday) but i was wondering, which one was better. My dad has all the chemicals in his shop but Im not sure if has denatured alcohol. We use acetone for cleaning most things. So i was just wondering if i could get around going and buying DNA at the store, and i could just use acetone.
rebfan04
Flowood, MS
Someone else might know better but I would not use acetone with CA except for cleanup. Use DNA on pen. Good to have acetone when your finger gets stuck to the CA bottle!
As you probably know Acetone is a solvent for CA.
soligen
Sterling Heights, Michigan
Get the denatured alchocol (DNA). Acetone is good for cleaning the wood blank BEFORE the first coat of finish, but once you start a CA finish, you cant use acetone to clean the blank between sanding grits. Once CA is on the blank, you will want to use DNA
Also, I recomend using DNA for general cleaning if it works just as well as the acetone. Acetone is kinda nasty stuff, so I only use it where DNA doesn't work.
G1Pens
Atlanta, GA area (Dacula)
In a somewhat similar thread recently it was pointed out that DNA does contain some water and could be detrimental to the CA. The suggestion was to use accellerator to clean the wood before applying CA.
Monty
Group Buy Coordinator
Pearland, Texas, USA.
BUT DNA is at least 5-10% water and water will cause you more problems. My first choice is CA accelerator followed by acetone.
Whaler
Sequim, WA, USA.
I use the alcohol prep pads to clean my blanks. I find it more convenient than having another bottle around to get spilled.
Millersburg, OR
I use acetone for a quick wipe down after sanding wood. after that I just use a dry rag. Acetone will soften the CA glue so a little dab will do ya.
InvisibleMan
San Jose, CA
I've been using mineral spirits with good results. Am I operating on borrowed time with that stuff? I use it on the bare wood - I don't sand between coats of CA usually.
Monty
The DNA you are able to by at the store is about 90% alcohol and 10% water. What usually happens is that the alcohol will evaporate off first leaving water behind. If you don't wait long enough for the water to evaporate, it may cloud the CA. Acetone has about 1% water in it. When it evaporates, it leaves less water behind. CA accelerator (most brands) do not contain water hence no problems once it has evaporated.
its_virgil
Wichita Falls, TX, USA.
I think I misunderstood what Manny posted. His first choice, and mine, is accelrator and his scond choice, and mine, is acetone. I use accelerator exclusively and acetone when out of accelerator. Alcohol is a problem maker with the CA glue finish. Those who have not had issues with alchhol and the CA finish are beating the odds but it won't last. The odds will get even :)
Do a good turn daily!
Don
spnemo
Tustin, MI
I used to use DNA but after some problems with clouding under my CA finish I switched to Acetone. I'll never go back. I use acetone instead of accelerator because it is cheaper and readily available.
Monty
Don
Don, I think you misunderstood what you thought you misunderstood.:biggrin:
You stated exactly what I was thinking.
rebfan04
Flowood, MS
Always learn something new on the board. Didn't know about the water content of DNA. Guess have been lucky so far with CA finishes. Will change over to Acetone for wipe downs. Thanks guys.
its_virgil
And, water will dissolve into alcohol quite readily. Water in fuel lines....add stuff to remove the water....what is it...alcohol. The water dissolves into the alcohol and is removed when the alcohol is burned with the fuel.
Leave the lid off the alcohol and moisture in the air will go into the alcohol. Not much but it doesn;t take much to make a good CA finish cloudy.
Don
crabcreekind
Eugene, Oregon
Don
Do you use aerosol accelerator of the squirt kind you get from psi?
its_virgil
I use bulk accelerator for cleaning blanks prior to applying CA for finishing. I use aerosol spray can when helping CA to cure. I do not use accelerator when finishing. When I use up the two aerosol cans I currently have (they were donated to me for using in my demos at the Desert Woodturning RoundUP)I will be getting the spray/pump from Mannie along with a jug of accelerator. I am hearing good things about his spray bottle. Mannie has the best prices on CA, accelerator, two part epoxy and accessories.
Don
Don
ctubbs
Murray, Kentucky
One more for Mannie's CA, Accelerator and his spray cans. I bought both the 8 and 16 oz cans on his first test buy. I have the 8 oz filled with Accelerator and my bride took the big one and filled it with cleaning solution for the kitchen. they are great to work with, come with several spray caps so you can produce anything from a stream to mist. The only thing better than his cans is his CA and Accelarator along with his service and prices.
DNA is an absolute NO,NO with CA finish. There is no way economically to remove all the water from alcohol. Even if by some magical process you were able to get 100% alcohol, as soon as you open it to atmosphere it will start absorbing water as it is hydrophillic.
Charles
