CharlesSharp
The drive belt on my Delta Midi Lathe is starting to look a little worn. Where can I get a replacement for a decent price?
Originally posted by dkennedy
The part number for the Delta LA200 replacement belt from Belts for Anything is 250J3. It will run you about $6.36 + Sh starting at .58 cents for 1st class mail.
The belts they sell are far superior to the OEM belts from Delta, however, the after market belt is about twice as thick and may not fit between the upper left (500 RPM setting) pulley and the headstock casting. I know of 2 other people that didn't have any issues, but I had to make an adjustment/modification to get it to work out for me.
I have double checked with the belt store and the part number I listed above is what matches the numbers on the Delta belt in their cross referencing system, but for some reason there is a considerable difference in thickness. I have been meaning to send my old belt to them so they can physically match it at their facility, but haven't gotten around to it yet.
