Scotti, that's not what I'd use them for. For me, anything on the ends of the blank can bring color in, even the Delrin, even though it's white. It's still foreign. The only way I know of, aside from turning between centers, is to start in the middle of the blank and sand outward, never coming back in after that part of the sanding medium is contaminated. I don't worry about it until about 600 grit. Then, when I switch to my Abranet pads (the big ones) it's simple to find a clean spot and start in the middle, work out. You can do this on even Holly and it will work great. I rinse my pads every night and they're clean and ready the next day. I use the Delrins for applying CA only. If you sand on them much they won't last too long.
I did go and check today, my Delrins (Johnny's) are exactly the same size as the metal ones.
Dale
