stoneman
For those using the Testors model decal system, is it necessary to buy the kit and software to use this? Or can you just use the decal paper and bonder spray if you want to use other images?
You need the bonder to seal the ink from the printing. You do not need the program as it is pretty cheaply written. I use Word and first print on a piece of paper and then tape a cut piece of the decal paper on it. It works so far but I have been having problems with the CA finish over the decal.
