Decal Issues
heritagebob
Porter, Texas
I am making a few decal pens for a local car club. I am experiencing an issue with parts of the edge and some middle areas of the decal turning a milky white after I have applied several coats of CA. (between the decal and the wood).. I have done several other decal pens and NOT had this issue. Any thoughts? Suggestions?
dbledsoe
Brandon, MS
I have had this problem when the decal does not stick down securely. You will probably find that when you turn it off it comes off in large pieces rather than slivers. Make sure you get all the air and water squeezed out when you apply the decal.
